1g bov leak...maybe??
PxIxSxTxOxL
32
Aug 13, 2008
chesterfield, Michigan
about two days ago i was droppin my buddy off and on the way home the car felt really suggish. when i stepped on it a little i got to about 2k and the turbo started sputtering like crazy. i hav absolutely no acceleration and thats and understatement. the sound it makes sounds like the boost is going almost straight thru the bov into the recirc tube. instead of hearing the turbo spool up you hear a constant pssshhhhh and its coming from the bov. its a 1g bov on a 2g eclipse. stock boost.
It happened to my car at about 100K I heard the BOV bypassing a ton of boost, and it sounded like a constant release of air pressure. Do a boost leak test as described in the FAQ and it should pin-point your problem.
What? If it's the 1g BOV, just replace it. WTF Whatever the leak is, address it accordingly. We can't type something over a forum and fix your car. Use your head when you figure it out.
What leads you to think the 1g BOV is adjustable? You have a lot of learning to do. I mean, A LOT.
Settle down man, he knows he has a lot of learing to do thats why he's here asking questions respectfully. OP you're on the right track in suspecting the BOV and getting the leak tester as you stated. Dont just replace parts until you've tested them to make sure they have failed, you probably already know that just commenting on some other peoples suggestions. Let us know how the boost leak test turned out. good luck
