Boost leak Maybe
Riceless92TSI
Dec 1, 2010
Carson, Nevada
I have a 1993 eclipse gsx and i think i have a boost leak because my vacuum is only -12 and I heard it should be at -18 or -20. I did a boost leak test but found no leaks, do you think i have a boost leak and where do you think it would be.
Vacuum is created behind the throttle plate. So if it's a vacuum problem check around there. Intake manifold gasket, injector seals, throttle body and tb gasket, etc... Where is your boost gauge hose tapped from?
vacuum leak != boost leak
Do a boost leak test with the crank turned to the proper position and the throttle plate open w/ all the spark plugs removed from the motor.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
  • For sale 4G63 SPAL 6.5 inch Low Profile Fan - Push
    SPAL 6.5 inch Low Profile Fan - Push $55 + shipping & paypal fees* these are great to use with...
