Resolved 1g Base timing with 2g pistons and cam question
tifsim
33
Jan 24, 2011
Marlette, Michigan
So I have a 1g with 2g pistons in it. Should i set the base timing the same as a stock setup or should i advance or retard it some?
Just curious as to what people had luck with.
Is there a difference between a USDM 5 speed turbo cam and a 2g USDM 5 speed turbo cam? Has anybody ever compared them and such?
I forgot to mention that it has 2g gsx cams in it as well. Is there actually much difference between a 2g and 1g 5speed usdm turbo cam?
I wouldn't run much boost until you get a way to re write the timing map.
Why would u say that?
