1G Idle only fixes with base timing set
91tsi617
Jan 15, 2006
boston, Massachusetts
Ok, I did search, and couldn't find anything close.
I have a 90 TSI I picked up with some gremlins. It has an idle around 1800 rpm. No surge. The biss screws all the way in. BLT wouldn't hold pressure, but I suspect a weak bov is the cause as it puffs air at idle (speed density system).(prior owner put a vortech bov on...why?...and there is no spring pressure adjustment like on a greddy).
I was playing with DSM link on it and when I select base idle the car drops to about 1000 and holds steady....any reason anyone can think why?
Could the bov puffing air out at idle cause the leak. I assume so but just want to be sure before I tear into it to deep.
