2G Setting base timing
4g63swap
258
Aug 9, 2003
ok I have a 95 Talon and I know that to set the base timing that I have to ground the brown plug, but here's the problem I believe that the guy that had this car before me cut the plug out for some strange reason so here's what I need, someone to tell me what colors are the wire(s) that go to the brown plug. Thats it.
thanks
4g63swap
Ha ha ha thats the funnies thing I have heard all day!!!!! :laugh: (You can't adjust base timing on 2g's unless your running a 1g cas.)
well in a 1G it's a plug on the firewall.. i honestly don't know off the top of my head what to ground on a 2G. you can check it without grounding the wire though if you have stock cams/cam gears... it'll jsut read different (i.e base may read a little high)
Poke around in the wire loom behind the batterey, mounted on the firewall, above the porportioning valve. It should be the ONLY wire by itself. Black if I am not mistaken.
-Rob
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
