1g, at idle, try to rev, bogs down then revs up.
panamarojo
178
Sep 8, 2008
KLAMATH FALLS, Oregon
What would cause my car to do this? While its parked and I try to rev the car, it will bog down, almost sounds like it is going to die and then revs up, no matter how far I push the gas pedal down, even if I barely push the pedal in. It will do this when I drive also, it will bog down and the car will buck around. I noticed after the car warmed up it didnt bog down as bad as colder. I already adjusted the TPS and checked for boost leak. Getting spark, replaced coolant temp sensor. Tried different MAF. I unplugged the TPS and it doesnt do nothing, it revs the same. I pulled the injector wires one at a time really quick to see if it would change while in idle and noticed the injector closest to the timing belt didnt change much when I unplugged it. Also unplugged the vaccum from the FPR to see what would happen and it just took a minute for it to start dying down. I re connected and it kept idling. Any help? And its also having a problem starting up, bout 5 cranks to start up, and still 3 to 5 more after engine warmed up, so at all times this happens. No matter if it was just running.
Ok so I did a boost leak test, Only one I could find kinda, was the throttle body, the coil that hooks up the the throttle cable, if I move that around I can hear the leak almost seal. Also I hear a leak either in the turbo section or 02 housing. But I cannot feel a leak anywhere around it, I went all the way to 30 PSI and still cant find no air steams, no bubbles. YouTube - Picture 013 Anyone know where a leak could be coming from on the first video? Here is one while I was diving. YouTube - Picture 018 and another one after it was a little more warmed up, it felt that it would go more up in RPMS. YouTube - Picture 020
kinda a long reach out there but check your ecu.... could be a leak,
and on a side note whats the year and month of your car and does it match your ecu... i had a car come to me and they had a 93 ecu in a 90 and didnt switch the two wires, (#6 and #14) i believe. check ecmtuning.com and look under knowledge and 1g ecu pin out info.
Biss already adjusted and caulked down. Thats the thing, I already put water all over the turbo and o2 housing, no bubbles, and I cant feel nothing. Any possible way it could be leaking from maybe turbo into o2 housing? Did you watched the first video?
Car is registered as a 1991, but the sticker on driver side says oct 1990 and Steve said my ecu is a rare 1990 cali eprom ecu.
Assuming you mean the sticker on the drivers side door frame then it should be a 1991. Because many of these cars have been hacked up at this point the ECU isn't proof of the model just another data point to consider as you fix stuff.
Production switch in June from 90's to 91's.
  • Wanted PASSENGER DOOR LOWER MOLDING
    WANTED
    • LA_gst
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
  • Wanted WTB 268 Camshafts & Zero Tick Lifters
    Looking to see if anyone has a set of 268 cams in drop-in condition. I know 268 is on the Rare...
    • Ice9
