1g 7bolt in a 2g
swarm
DSMtuners Server Guru
466
Mar 26, 2004
Spokane, Washington
I bought a 1g 7bolt thinking it should swap in directly.. I put the 1g 7bolt in the '95 eclipse and the bellhousing of the 2g tranny seems too large. i tried searching for this, but didn't come up with anything fruitful. i have a picture too if it would help.. any ideas on this? anywhere someone could link me to see what i should do?
The only question i have for you bro, is why? Any 1g to 2g swap that should be done is the 6bolt swap.:confused:
Because it is cheap.
It will work. My brother has a 1g 7 bolt in his 1995 GST.
Sweet. is he on the forums? can he shed a little light on this? is the rest plug&play?
There usually is a shield between the tranny and engine block. Get one from a 2g and it should cover that up without a problem.
Ah, ok. thanks! I'll check that out
Yes, he is. His name is snowborder714. However, he bought the car with the 1g engine already swapped in it so he probably couldn't help you out here. But if you have a specific question we could probably look at his car to try and get you an answer. Sorry.
