2G 1g 7 bolt in a 2g help
95_gst_turbo
56
Nov 20, 2014
weidman, Michigan
Hey everyone, I need a little help and some suggestions.
So I recently went ahead and swapped a 1g 7 bolt into my 2g that had a rod knock. The 1g motor ran when pulled and the 2g motor ran when pulled ( just had a rod knock ). So I got the motor dropped in and all hooked up, how ever I'm not getting any spark.
This is in a 95 eclipse gst btw.
I wired up the CAS and I realized the first time I mixed the blue and the black up. So I corrected this issue and im still not getting any spark on any of the 4 cylinder.
The TPS sensor wires are snipped off due to us using the connector on a previous project because I didnt intend on putting this car back on the road. Also the sensor that is ontop of the intake isnt hooked up due to the 1g intake. I dont see either of these causing no spark.
Any help or suggestions would be much appreciated. Thanks
you use the 1g head? i would have just used the 2g head, much simpler, then it all just plugs in
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
