1G Help with parts - 7 bolt fwd flywheel
Look the thing is I had 6 bolt non turbo FWD but I got new engine and it’s 7 bolt and shaft diameter is like turbo version 85mm diameter so I’m kinda confused
You need a 7 bolt fwd flywheel.
Fwd flywheel is larger diameter than a awd flywheel.
6 bolt flywheel will not bolt to a 7 bolt crank as 7 bolt has one more flywheel bolt.
It is possible to use a N/T clutch / flywheel with an AWD transmission: N/T Flywheel and Clutch Combo in an AWD.
I imagine that the reverse, an AWD clutch / wheel in an N/T transmission, should be possible as well, but I'm not aware of any recorded use of this scenario. However - and worst case scenario - there is a suggestion in the link Tony provided to machine down an AWD unit to work in an N/T application: 1G FWD NA Flywheel Help.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
