Resolved Fwd 7 bolt flywheel: turbo same as non-turbo?
Solution
Ok I'll check
They are different. The 7-bolt non turbo flywheel is not stepped and is smaller in overall diameter than the 7-bolt FWD turbo.
No they both 7 bolt one is an early 4g63 non turbo like 93 or so and I have a 95 turbo Gst doing a rebuild and a friend has it for cheap.
Ok I'll check
Solution
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
