2G 7 bolt with 1G Transmission
34tftf
37
Mar 21, 2011
Chambersburg, Pennsylvania
I am going to be putting a 2G 7 bolt block in my 1G, I have a 1G Transmission, I was wondering if everything would mount up properly. Also I was wondering what generation clucth and flywheel should go on this? THanks
I'm not sure the engine mount on the driver side will fit. You can use any turbo dsm clutch, theyre all the same but you need a 7 bolt awd flywheel.
There won't be a place for the front engine roll stopper to bolt to the block. You'll need something custom fabricated for it or consider running without the mount (would require the other mounts be upgraded/stiffer).
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
