zcopp
- 42
- Dec 25, 2025
Arizona
Hello!
I've bought an ECMLink V3 for a 1990 M/T car from a known running car and have installed it on my 1990 M/T GSX. The car starts up reasonably OK.
However, there is a very odd issue with the ECMLink it's self. If the car is put into IGN-ON, I cannot connect to ECMLink. If I start the car, I can then connect to ECMLink and it works as expected. I can then make updates and save them or stream live data. When the engine stops, the streaming data will stay on for 6 seconds, at which point the MPI relay clicks off and the EMCLink connection immediately dies. If I kill the engine and switch it back to the IGN-ON position, the ECMlink connection stays on... but it eventually dies ~25 seconds later. It seems to "fritz" out at about 20 seconds then drops completely by 25 seconds.
I've tried multiple laptops with the same result. Cant connect in IGN-ON unless the car is running or in that post-running state.
I've also checked IGN-ON power at ECU 102, 103, and 110. 12v and 110 loses power if ignition goes to off. I've also checked the MPI relays 4 and 5 (12v hot back to ECU and other things...) and everything seems to be in order there.
I have set the ECMLink to run the fuel pump on IGN-ON instead of the short prime; it IS running so I'm pretty sure the ECU is powered as expected and at least functioning. Obviously as well because the car starts and runs, reacts to ECMLink live changes, etc...
I also did troubleshooting on the diagnostic ports. Pin 10 showed 3.5 volts as expected on a 1990. pin 12 has continuity to ground. Pin 1 is supposed to "fluctuate" but it seems to hang out at .013 volts at IGN-ON. I'm using a fluke multimeter on DC voltage to check that; this is the only thing that seems slightly "off". I would be all over this however it connects just fine when the engine is running... so I'm at a loss!
Anyone experienced this before? Car's pretty stock and I'm not tracking any major wiring hacks in the ECU harness area....
Sources:
ECMLink troubleshooting:
www.ecmtuning.com
ECU Pinout:
MPI pinout:
Sources:
connectionproblem [ECMTuning - wiki]
MPI pinout:
