2G 1998 Spyder GS blinker issue...
Jdalvarez117
Supporting Member
67
11
Apr 6, 2019
Corpus Christi, Texas
Alright guys, I need a bit of help.
So, I recently got my hands on a 1998 Eclipse Spyder GS, and I've gone through at least 20 10a fuses for the turn signals in the past two months. Seriously, you should see my passenger floor board. It happens randomly. I could drive with one fuse for two days, or blow three in one day, rain or shine, dry or wet.
One of the firsts things I did was check the plugs all the way around. I found the front right plug had a terminal pushed out,so I rewired another plug in.
Unfortunately, this did not solve my issue, and I'm not really sure where to go from here, other than going through the entire harness from the fuse box to the plug ends.
Have any of you guys had this issue? It's been driving me up the wall.
Alright, so I checked all of the bulbs and sockets and didn't find any corrosion that couldn't be wiped off with my finger, but I did find two bulbs with flattened contacts on the driver side.
I had a problem like that long time ago. Turns out a dime fell into the cigarette lighter holder. Was causing a ground when vibrating.
Did you look at the wiring diagrams? Have you do e anything to the car lately prior to this? I mean ANYthing
^^^^^ THIS ^^^^^
One thing not to overlook is the blinker stalk on the steering column. They go bad sometimes too. I've personally had to replace at least 3 on the 8 DSMs I've owned. Simple to do if needed. Do you know if there is or was ever an aftermarket alarm installed? They can cause issues of all sorts if not installed/removed properly.
I haven't done anything but replace the shifter with a short throw after discovering one of the previous owners just hacked the stock shifter in half, ground down the shaft some and epoxied a shift knob to it.
It was doing this the day I bought it. Before that, it had aftermarket fog lights installed, a random ass toggle switch wired in to turn them on.(which didn't. It just turned on the headlights for some reason.) Anything with a boot or bushing in the front end had been replaced. Which I oversaw while waiting to buy it.
^^^^^ THIS ^^^^^
I believe it does have an aftermarket alarm in it. Not sure, but there's a little black box with a led zip tied in under the dash. And I havent messed with the blinker stock yet.
Also there's this little toggle switch that was mounted to the trim underneath the fuse box that I have not a clue what it is for.
Also also, I have an update. It seems the fuse only ever pops when I have the right hand blinkers on. I've not had it pop with the left hand blinkers on that I recall.
I would start there. Remove the socket, turn on the blinker and wiggle around. Might find a short easy that way. Alarm is a big suspect too.
Definitely not what I was thinking, so that's good. I would still remove it though. It could he interfering. Are you able to see where the wires hook up?
All up in this nest of shit
I got most of this stuff undone.
Here's where I am so far.
Got the alarm system harness out..
Now I'm working on rewiring the ignition back to where it should be.
