2G Headlight/fuse box wiring
DSM98GSX
151
35
Apr 16, 2008
Tucson, Arizona
Hey guys,
Got another wiring question. Been a while since I pulled all the wiring and car isn't at the house but all the wiring is. My question s on the main fuse box with specifically headlight wiring. I've rewired the box to supply the main 40 amp headlamp fuse for the headlamp relay (+12V and trigger +) and tail lamp relay (+12V and trigger +). The output wire from the headlight relay feeds the lot beam headlights, high beam fuse and the other that goes to the fog lamp fuse (not being used). Where does the other wire from the high beam fuse go!? Does this go to the pink wire for the high beam bulbs? Am I thinking about this right?
I've searched for the 2G headlight wiring diagrams but to no avail. Can someone point me in the right direction! A wiring diagram would be helpful too.
Thanks in advance!
-Nic
The "other" end of the high beam fuse runs to the high beam indicating light on the gauge cluster.
