2G 2g fuse box rear top plug wiring
dmaffo
59
Feb 9, 2009
toronto, ON, Canada
On my quest to clean up engine bay I cut snip relocated things and finally last night I thought all done.
Until the final inspection and I found a loose wire and no written tab to go along. Cant figure out what this sucker was plugged to.
1995 gsx driver kick panel fusebox..unmount it and on reverside (back)
On the top there is a yellowish plug.
The 4th pin from left to right is a thicker gauged black wire with white stripe going down it. Pretty long too so not even sure where I would have snipped it.
Could it be a ground?
Plug is actually black, the yellow part is just the lock to keep the pin in place inside the connector.
Black/white is usually Ignition Power on these cars, as for where it goes I can look at my harness but that won't be until tomorrow.
[/URL][/IMG]
Pin 4 on B75 runs to pin 4 on A40 which is your generator/alternator relay!
Thank you Anthony!!! In case anyone ever searches this forum for same there is your answer!!
So if you have a 1 wire alternator, then you can clip that sucker out!
