1G 1990 Talon cranks but no spark
90sT@lon
3
Sep 17, 2023
Littlerock,Ca, California
Wiring is done But car has no Spark any info will be appreciated
The car cranks but wont start i checked the spark and its dead ,When i bought the car it had melted wires thats the reason why i took off the dashboard to make sure i wanst missing any wires to replace ,I will be checking the coilpack
You are going to have to give a little more info. Could be anything from a bad ignitor to a bad ecu.
Do you get a check engine light for about 5 seconds when you first turn the key?
Do you have injector pulse?
Hello, I replaced the coil pack and the car still has no spark also the dash still off. I'm gonna have to put it back on to see about check engine light. MPI relay is good, the relay inside by the computer clicks when I crank the car.
