17x9 35+ offset Good Choice! 2g!
Are all confirmed 17x9 + 255/40-17 users 2Gb? Seems that way.
I have a 2Ga. Right now I have 5mm spacers in the back but I am not sure if they are needed. A local AZ guy - Phuong (gsxwingz) had that set up on his 2Gb and he told me that the spacers are necessary so I got them with the wheels.
Thank you for confirming this. The "info" had been tossed around a lot without solid confirmation.
Is this test fit picture 2Ga or 2Gb? The two are simply bolt-up interchangeable?
I ask because I ran 245/45-17 Nitto NT-01 on evoIX 17x8 enkies, and without a spacer they were locked against the upper curve of the arm. With spacers (5mm), they rub under load on the road course. I've since sold them off.
That picture is of my 17x9 +35 on the 2gb spindle. The clearance looks a bit smaller than it really is, but it is still only about 2-3mm. The rears swap over directly. The only difference was the curve is a little 'deeper' on the 2gb. I swapped them over directly with no problems and have been rockin' out ever since!
18x9 35mm with 255/35/18 tires, koni and H&R sport springs works perfect for my 95 knuckles and no fender rolling. :rocks:
The +45 offset is going to really hurt any wide tire you want to use.
Here's the data when I measured the knuckle clearance between a 2ga and 2gb.
http://www.dsmtuners.com/forums/152189873-post18.html
And going from that 8" wide, +35 Evo wheel to your 9", wide +45 RPF1, according to this offset calculator, you'll have 23mm less inner clearance and it'll stick out another 3mm.
so from my understanding there is no real way to change a offset to like 35mm if it came 45mm shipped? could i use spacers to achieve better clearance? i also dont mind if the wheels stick out a little. i forgot to mention that im getting H&R sport springs soon so it will drop that car around 1.7" on the front and 1.4" to the back. if it is going to be a pain in the ass to achieve the clearance then im just going to go with the 17x8 model.
The wheel diameter doesn't really matter much. It’s the tread width and overall tire diameter that determine whether or not the tires will fit. +40mm offset is the sweet spot. It places the tire very near the center of the available space (keeping good suspension geometry). This becomes more and more important as width and/or height is increased over stock tire size. It is assumed that only a reasonable amount of lowering (up to 1.5 inches) will exist.
Its seems for the 2G, if you are going to want to run 17" wheels, the widest you can get there without some work is 245/35/17 (+50mmm offset). That will still give you 6mm of knuckle clearance and 17 mm of fender clearance. Anything less than say 15mm or less of fender clearance will require some type of fender rolling depending on the offset of the wheel.
But if you go with a +40mm offset, the best you can get (without fender mods) is a 225/50/17. Here are some charts with the data I am referring to for 2G's. Will show 16, 17, 18 & 19 inch wheels for fitment.
Orange = Significant deviation from stock tire diameter - Not recommended.
Green = Adequate clearance.
Yellow = 15mm or less fender clearance may require fender flange rolling.
Red = Zero or neagtive clearance.
Will this work with stock suspension? And if I drop 1" with an aftermarket suspension?
2000 Mustang GT Wheels
17x8" +30 245/45/17s
AGX /w Skunk2 coilovers
4 fingers front
5 fingers rear (Yea I lifted the rear, raked it for more oversteer)
Alignment in spec
Before I got sideskirts
I love these wheels and the I went +1 size on the tires and my speedo reads the correct speed now.
Im a noob when it comes to 2G cars and I think this is the most helpful thread I've found about tire/wheel fitment. I dont know what the differences are for a 2GA and a 2GB. Mentioned earlier were knuckles, and swapping on 2GB knuckles. anybody care to explain how this affects wheel/tire fitment? Im looking for pure grip and handling, and so wheel/tire ftment is important.
The curved part of the spindle/knuckle that curves up to the upper control arm is the only part with clearancing issues. The difference between the 2ga and 2gb ones is about 3mm. I bought my current wheel setup (255/45/17 on 17x9 +35) and after getting a 2ga donor car for my AWD swap realized they just barely hit. I tested them out on my friends 2gb and they fit, but just barely. I swapped the 2gb spindles onto my car and they have been fine. Here is a picture of the test fit.
I hope this pic is before you fixed the spacing issue. I had more room than that on my 18s and the sidewall got owned. Rather run a spacer than chance that tire getting owned on a curve. Tires stretch while moving a 3000 lb car.
Hey do any of you guys know if a 18x8.5 with 32 offset would fit on my 98 spyder?
I'm looking at 18x8.75 +20 offset I wanted the 35mm offset but after reading I have concerns I'm riding all stock
Ill be running a 17x9 +35 with a WIDE 255 tire.
Might even go 17x9.5 +35
Cant wait!
I run 17x9's w/+35mm offset and 255/40 17's Toyo RA-1's.
They stick out about 1/2" - 3/4".
Only 2gb rear knuckles will allow that wide of a tire w/+35mm offset.
> +35mm offset and the tire will rub the knuckle.
Anything less will push the wheel/tire out further and your car will look like a skateboard...
To each their own.
To each their own.
Can you post up some profile pics of you wheel setup?
It would be greatly appreciated.
Please... you guys are running way too high of an offset. I had SBC RPF1 18x9.5 + 15 on 265/30/18 SR3
Now that was something too look at. Lets just say ended up selling them within a matter of weeks
What ride height? Spring rates? What suspension/handling mods did you need for that to be effective on track?
That combo had to stick out at least 1.5", so how did you keep from slicing the rear tire in half with the fender? Flares?
17x9 +35 (+43 with an 8mm spacer)
255/40/17 Bridgestone Potenza RE11a's
-2.3* camber in the front, -2* in the rear
Lowered, uhm.... a LOT... on D2 drag coilovers, LOL
No clearance issues on the inside, rubs a little bit on the rear fenders when I hit a hard enough bump, so I'll just roll them a smidge more.
To each their own.
My car is not a skateboard.
17x9 +29 with 235 width AD08 (8.9" center section). They do not stick out and slightly rub with one camber washer in the rear.
Most people are running too wide of a tire IMHO. 235-245 (or an actual 9" wide tire) is basically the limit of stock (rolled) fenders if you're doing road course work. Tires misshape too much on high speed handling (AKA tire deflection) if you're really hitting up grip and you'll rub control arms with the 4mm of clearance to the arms
[ame=http://www.youtube.com/watch?v=jLoQTzdatl0]Brake Glow and Suspension Action - YouTube[/ame] (Not a DSM but you get the idea).
Effing perfect.
Exactly what ill be doing.
17x9 +35 w/ 255s
  • Wanted 6 bolt NT water pipe
    • chrisman287
