14b/16g Rebuild part numbers
black92_tsi_awd
217
Oct 8, 2004
Yates City, Illinois
I need the Mitsu part number for the seal plate oring.
For that matter if anyone has the parts list for 16g rebuild kit part, I wouldn't mind having it. The CAP software doesn't show any of the turbo internal part numbers.
14B/17C/19C-specific kit = 49178-81110; includes:
49168-18900 : Flat Seal Plate
F3153-10000 : O-Ring (CHRA & Cover)
49168-22202 : Oil Deflector
49170-14020 : Bolt for Clamp (CHRA & Turbine Housing)
49179-14010 : Nut for Clamp
49178-22300 : Snap Ring (For Journal Bearing)
49168-23201 : C-Clamp ( Insert)
34336-04100 : Gasket for oil drain Pipe
49168-22100 : O-Ring (Insert)
49178-42210 : Nut for turbine shaft (Left)
49178-42201 : Nut for turbine shaft (Right)
49178-21400 : Journal Bearing
49178-21600 : Thrust Bearing
49170-23100 : Piston Ring (Compressor side)
49178-23100 : Piston Ring (Turbine Side)
49178-42100 : Thrust Sleeve
49178-42300 : Thrust Ring
49168-22501 : Long Seal Insert (Flat Back)
16G/18G/20G-specific kit = 49178-81210; contains all of the same parts from above except the following:
49178-22510 : Superback Seal Plate
49178-42110 : Short Seal Insert (Superback)
If you need that seal plate, PM me....I have a serious supply. ;)
Buying in parts will cost u an arm and a leg if buying by mitsu numbers, just get s reviled kit from g-pop shop for a lit less and the will be good parts
I already buy from Gpop and Jusmx141 8)
I just like to look thing up in CAPS sometimes if I just want to order a single part. Plus I'm an engineer, so I get anal about things sometimes.
