- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- MBC set to 20psi (for dragstrip), VDO Boost Gauge, Autometer Oil Pressure and Voltage, Buschur Cat back exhaust, Summit Catch Can
Fabricated 2 1/2" Upper and Lower Intercooler Pipe, Rewired pump, Fabricated Headlight Air Duct, Buschur Downpipe and Test Pipe, Fabricated 3" Intake pipe, Walbro 190 Fuel Pump, Window Welded all engine mounts, GM Maf and translator in blow through config, Supra SMIC, 550 injectors, Tial Blow off valve, ACTY2600 and Findaza flywheel
- Mods-Engine
- STOCK, ARP Head Studs, no balance shafts
- Mods-EMS & Logging
- EPROM, MAFT, Pocket Logger
- Mods-Drivetrain
- ACT 2600 Clutch
- Mods-Handling
- Poly Bushing in Front Suspension Arms, KYB AGX Struts
