14B Casting numbers
garrett21
61
3
Jan 26, 2006
Turlock, California
Ok what I have, appearers to be two 14b turbos. The look the same. I want to know if they are both 14b's or is one something else.I don't want to sell one saying it is a 14b when it is not. I have searched the topic and called the local dealer. The dealer is going to get back to me in a few days.
If anyone can help me figure out what turbo's i have, here are the numbers:
The first one has a casting number of 49178-01010, as far as I can tell this is a 14B part number.
The other turbo's # is 49178-01400, not sure if this is a old 14b casting # or what. Also on this turbo the whole number is casted, where on most TD05's there are two #'s that are stamped.
I will add some pics later. Thanks, in advance.
Stock 6cm turbine housing should have 78-11020 cast into it. Do they have a stock TD05 compressor cover on them? If so then most likely it is either 14b or a 16g variant. Get us some pics.
are the compressor wheels the same? the 14b has straight blades somewhat like the exhaust wheel whereas the 16g has curved blades.
Pictures will help us give you a sure answer
