13g oil feed line
DSM BoosT
150
May 5, 2009
hudson, New Hampshire
I'm running a 14b/16g oil feed line on my td04hl found a banjo bolt from a shop here where I live maybe I can go check it out If they still have it.
What's your email ill Take a pic of mine and show you.
Why not a new OEM feed line from the head? You don't want to be supplying one of these turbo from the filter housing anyway when they're designed to be fed from the head.
JNZ has the OEM feed line for $23 brand new.
JNZ Tuning Online- OEM Mitsubishi Parts
This might sound like a dumb question but, why wouldn't you want to feed it from the OFH? I just ordered a similar kit from Bonehead to use on my 14b, which will soon be upgraded to a 16g.
....and this may sound like a dumb question, but why would you ever stray away from what obviously works?
Mitsubishi knows where to source the turbo for the proper pressure and restriction; if they felt the turbo needed a higher pressure oil source, they would've done so at the factory. By you installing a larger -4AN feed line with no restrictor, you're throwing off the entire balance of the oiling system by giving the turbo more volume and more pressure than it requires, and possibly more than it can efficiently drain.
Yeah I just ordered the part from JNZ its coming in Thursday hopefully everything works out I hate not being able to drive her, all of this because of my stupidity when taking the head off :(
