oil feed line
donovan983
Jun 11, 2009
hamilton, Ohio
ok i looked all over and cant find what i am looking for.
I need to know where and what part i need to order for my 97 2.0 turbo.
i need the oil feed line for it. I see the ones that go to the oil pump. but im runing a oil cooler. i hear that i can bolt to the top of the head. i guess i need that line runing from the top of the turbo to the top left of the head. any ideas? ty
1. Speak English.
2. Post in the proper sections.
3. Moved.
speak english? um ok. dont understand that one. but thank you for moving my post to the right location. for some reason i have issues posting in anything else. hate that i have to wait 30 days and there is a post count before i can go post in other places.
But still. do i tie into 1 or 2. if you check my image you will see and understand where i mean 1 or 2. also i see some people saying that getting my oil from the oil pump i get to much oil pressure. but the turbo i am installing was ordered from. 1997 Mitsubishi Eclipse Turbo Charger from turbochargerpros part number is 40-30001. and it is not a ball bearing turbo.
You will read the grammar and spelling rules. Now.
"Use proper spelling, grammar, and punctuation if posting in our Tech Forums. Internet Explorer users should download IEspell. We suggest using . Use Dictionary.com if necessary. "
You won't make the minimum post count to post in other forums if you continue on this path.
Yea i have alot of work to do to this car. I just picked it up not to long ago.
But anyways. you guys say use number two for the turbo feed line
I have my oil line ronning from my head because down by my oil filter the fitting is stripped. Alot of people go from the head instead, they have many forums on where to place the oil line look around.
right but my turbo isnt a ball bearing turbo so there isnt enough pressure on the head. it must come from the oil housing.. all stock minus the oil cooler.
