oil feed line
jbl_5star
150
Dec 14, 2009
Puyallup, Washington
the oil feed line at the valve cover, the inside is stripped the bolt wont tighten down.. what is the best way to fix that???
and how long of a fuel main line (the line that connects to the filter) where does it connect at? is it one line from the tank to the filter?
there is no oil feed line that connects to the valve cover, you must be talking about the PCV valve. if its the spot your talking about, it should be at the top left corner of the valve cover facing it from the front of the car. if that is striped then i would just JB weld it until you can find another valve cover.
the oil feed line for the turbo is on the actual head of the engine.
yea i wasnt thinkin... its at the head, its stripped the line bolt wont tighten down.. whats the best way to fix that; heli coils? n how would i keep the metal shavings from drilling out of the head>??
and whats the length of the stock steel fuel line? does it go from tank to filter in one long piece>??
