1.8 SOHC Cam Timing Dowel or Mark?
GT94_Eclipse
May 15, 2011
Oviedo, Florida
I’m rebuilding my first engine, a 1994 4G37 1.8 SOHC stock. I received my head back from the machine shop with the cam dowel was at the 12 o’clock position. I’m confused, after a mock-up and valve clearance test, I noticed my cam sprocket timing mark was at the 9 o’clock position. So here we are, my repair manual clearly shows the timing marks for the cam at the 12 o’clock, I have my tear-down photos showing the same. But the machine shop, a Mitsubishi rebuild video I bought and every thread I can find on the DSM site notes the dowel pin to be at 12 o’clock position for correct timing. Which way is correct, and second, from my understanding the head cannot be configured any other way, correct? The cam lobes turn the rockers and valves at it’s design rate, a machinist assembles the head, but doesn’t adjust any timing (excluding) tweaks to the cam/ports/valves etc..prior to the assembly.
Dimple on the cam sprocket should line up with the notch (at 12:00 positon) in the cam rear cover guard along with the other sprockets aligning up to their respective marks .... the dowel pin thingey is for the 2.0L motors ...
not that all hard in doing T-belts on a 1.8...
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
