Crank Timing Mark 1.8 SOHC Same for Timing Belt 'B' and Timing Belt??
tight_tsi
91
Jul 21, 2006
Lincoln, Nebraska
I was just wondering if you are supposed to use the same timing mark that is circled in red for both of the timing belts? If you look at the 2nd picture, there is an indentation on the gear for the main timing belt. If someone could please let me know what to use when timing I would appreciate the help. Thanks!
if you are not sure on if you have the timming mark right pull the number 1 spark plug, stick a long screw driver in the hole and if the piston is all the way to the top then you have it on time if it is not on top then you have the little plate on backward good luck hope this helps you out
the first picture is the timming mark but you can put it on backward so check just like I said
    • george bromwell
    • pma1123
    • Sdcryan1
