- Thread starter
- #26
GoldNugget90
- 9
- Aug 8, 2023
Tampa,
Florida
Seems reasonable, I'll toggle some more (and still do the TPS voltage adjustment you recommended). I'd rather spend more time getting a better idle than rush it, doing my best not to blow it up.I don't know if its been said but I sit in my car, idling, and play with the global first to try to get my LTFTs and STFTs close to zero. They never are so I reduce or add global a bit and look at my Ecmlink log that I am running and look at LTFTs. I adjust to get it close, or within +/- 5% then I fiddle with deadtimes for STFTs to bring them within 5% +/-. A note here, YOU CAN RUN NEGATIVE DEAD TIMES. It should idle pretty good and drive ok but the WOT will not be correct. I haven't got that perfected when I mess with my settings yet.
Marty
Don't worry, Nugget, you'll be totally fine.
Don't speak that into existence! My TB and components have only <1k miles on them so they *shouldn't* break. Had the car 3 years and it's spent way more time on jackstands than being driven, mostly by choice. I don't use the A/C, and in FL, that greatly reduces my comfort level 8 months of the year...I wanna hear the car windows down in full glory!
mine had 70k on it at the time so there was no reason it should've snapped. This was a little over a year ago shortly after I bought it and I was as surprised as anyone. Don't worry, I'm not wishing that on you. Just my daily reminder to SEND IT.
Considering just getting a new battery with more power, but I dunno. Nothing changed from driving to today so unless a ground shook loose I'm stumped.
