Activity Feed
Live updates
  • Ludachris replied to the thread DSMTuners Members Pictures.
    · 1,160 94,817
    Oh hell, it doesn't matter for attachments - I have it set so that people need to be logged in to view attachments, so the membersonly bbcode isn't needed for that. Everyone who has posted images in this thread can feel somewhat comfortable that...
  • 19Eclipse90 replied to the thread DSMTuners Members Pictures.
    · 1,160 94,817
    Well, maybe Chris needs to edumacate me, too.Mike - some members of site staff can edit posts for you so, for future reference, report it with what you want fixed and it can be corrected.That said, I tried editing your post with that code and...
  • Ralph-RaccooN replied to the thread 1G What was this bracket location used for?.
    · 2 167
    You must be registered to see element. Its a wire tie on my 89 Galant.
  • Ralph-RaccooN replied to the thread Motor bogs down when step on gas.
    · 6 250
    take good macro shots centered around the capacitors, its the cylinder shaped devices, I see 4 of em. Even if it was rebuilt from a past failure, corrosion could of destroyed a trace. you gotta be eagle eyed, you can also use a multi meter to...
  • 92AWDHX40 replied to the thread Street Build Project 1g (NBA DSM).
    · 378 53,397
    Very cool
  • dwb replied to the thread 2G Battery terminal connector.
    · 3 110
    I would recommend a terminal more like this and an eyelet lug soldered on the battery cable. You must be registered to see element. If you go this route, make sure you get one with a wingnut post that fits you exising eyelets. The type you linked...
  • diambo4life replied to the thread DSMTuners Members Pictures.
    · 1,160 94,817
    Unfortunately, there is a time limit on the edit function lol.
  • CKOPOCT replied to the thread 2G Battery terminal connector.
    · 3 110
    Yes. But why do you need to replace the terminal? If it won't clamp tight enough, then okay. But if the issue is the rust and corrosion, just use a wire brush to clean everything and get the terminal back to shiny clean metal. If you replace the...
  • Scraggybeard posted the thread 2G Battery terminal connector in Newbie Forum.
    Need to replace a loose terminal on my 1996 GST. Here is what is in there now, will this replacement work if I attach the side pieces to one of the verical bolts? You must be registered to see element.You must be registered to see element.
  • steve replied to the thread 2G New noise.
    · 10 263
    It looks like three profiles for the same nice looking car.I second the thought that this is not ECMLink related but if you post your current log (use Add Photos and select an .elg file) we can double check.
  • Robert Schele replied to the thread 2G New noise.
    · 10 263
    I copied the file directly from the ECU to the new laptop so there should have been no errors or mistakes. I am pretty sure that it is a bad pulley because I have seen small shavings down along the side of the timing belt cover for a little while...
    · 1,160 94,817
    Use this, without the underscores.[_membersonly_] Content here [_/membersonly_]
  • 99dsmer4g63 replied to the thread 2G First Gear Pops Out.
    · 21 470
  • DSMPT replied to the thread 2G 6 bolt 4g63t swapped into a n/a 4g63 EU car.
    · 13 304
    Just an example to share : the 1st pic is EVO1~3 ECU pinout, the 2nd pic diagram is for early EVO and the 3rd pic diagram is for 1996 euro 2g. You need to subtract 20 from the euro 2g connector B-56's pin numbers to match with the early EVO's...
  • jersygsx posted the classified ad For sale 4G63 ECM Tuning Electronic Boost Control Solenoid in DSM Parts Classifieds.
    ECMtuning Boost Control Solenoid $45 + shipping and paypal fees* these are $99 on their websiteYou must be registered to see element.You must be registered to see element.
  • jersygsx posted the classified ad For sale 2g 2G Hatch Side Compartment Door ( completely intact ) in DSM Parts Classifieds.
    2G Hatch Side Compartment Door $30 + shipping and paypal fees* tabs and locking mechanism are intact * grey in colorYou must be registered to see element.You must be registered to see element.You must be registered to see element.You must be...
  • GzusEclipse98 posted the thread 420A Advice on Ignition parts in 420A Bolt-on Tech.
    So I thought I'd be tackling my suspension after getting my brakes done, but I've been made aware by my mechanic that one of my ignition wires (or spark plug I don't exactly recall which it was) is starting to fail, made evident by an audible...
  • miliman13 replied to the thread 2G New noise.
    · 10 263
    So many automatic!!! A lill jealous. Can you post a video ?Is it possible you selected something on the last/new PC and didn’t notice can you compare logs ?Can you play with any EVAP related options as a test?I’m doubtful link has the...
  • jamel16 replied to the thread Street Build Project 1g (NBA DSM).
    · 378 53,397
    Finished finalizing the gauge placement. Installed the CanChecked MFD15 gauge, added the screen selector knob, and carbon block off plates. Very satisfied with the outcome. You must be registered to see element.You must be registered to see...
  • Dsm_canadian_mike posted the classified ad For sale 4G63 Parts in DSM Parts Classifieds.
    Parts2G rear differential cover (Will fit auto and manual) $75 1G rear differential cover (Will fit auto and manual) $50 1G thermostat housing with thermostat in it(come off a working engine) $80 1G/2G rear manual differential ring and pinion...
