Resolved Advice on Ignition parts
GzusEclipse98
64
25
Jan 6, 2025
Bronx, New York
So I thought I'd be tackling my suspension after getting my brakes done, but I've been made aware by my mechanic that one of my ignition wires (or spark plug I don't exactly recall which it was) is starting to fail, made evident by an audible tick in the engine bay, seems to be the 4th cylinder ignition wire.
Since I'll have to change the ignition wires I thought why not just tackle ignition maintenance altogether, given I have no clue if any of those parts were replaced or the last time any of them were done so. As such I plan on getting spark plugs, a new ignition coil pack, and of course new ignition wires.
For spark plugs its between NGK or Denso, either Copper or Iridium. On one hand I would like for the spark plugs to last as long as possible so NGK Iridium laser/ Denso twin-tip are on the table, but I get that copper is also a valid option since I don't put too many miles on the car anyways even as a daily driver (At least that's what I think, I got the car Dec' of '24, at 57,XXX miles, and just this week crossed 65,000 miles on the odo). Getting the right plugs from RockAuto I have to search via the Dodge Avenger, as with the 2L I4 Eclipse (Non-Turbo obviously), I get spark plug results for the Turbo model i think, as the spark plug part number should end in 11 (at least for NGK) but they don't so I assume RA is displaying the 2G Turbo spark plugs even for 420a 2Gs.
As for the ignition coil, I see that one by Mopar can be ordered on RockAuto but not thru the NT 2G Eclipse, it would appear via the 95-99 2L I4 Dodge Avenger. I assume it should be perfectly compatible since both Eclipse and Avenger have the 420a Engine, unless there's a reason why it's not available for the NT 2G Eclipse (it is the most expensive option though :/ ). Other than Mopar I am considering Blue Streak (Standard Motor Products), which I read from another forum member Black'98DSM as being capable of producing a strong ignition when paired with appropriate ignition wires and spark plugs. Aside from those prior two being the primary consideration, there's Delphi (of which I so far have a good experience with their Control Arms) and Hitachi (a name I recognize from TV electronics generally, I expect they'd make fine electrical components, at least for Japanese vehicles, although the 420a 2G or DSMs in general are not really Japanese vehicles, made in Normal IL).
I think I know to stay away from MSD for the ignition coil based on the advice from the same forum member as noted earlier, and I kinda get the idea that VMS would be a similar case, but I've not seen much reviews for VMS's ignition coil in so far as the Chrysler/DSM application, it just kinda gives the same impression being advertised in the same way as MSD.
As for spark plug wires I am considering NGK, Blue Streak (SMP) and Taylor Cable Thundervolt (also following the advice of Black'98DSm for this third pick). My goal is for the ignition to be refreshed and be as good if not better than stock and long lasting. I get the idea that I won't need the highest performing wires so I don't think I need Granatelli unless there's no reason not to go for it assuming it makes no difference and only benefits, remember that this is for a daily driver stock car with no mods.
Any input or advice would be helpful and appreciated and thank you for your time.
I'd just do plugs and wires and leave the coil alone unless it were problematic. The OE ignition coils can last a really long time. Also copper plugs need to be replaced at roughly 30k miles on E10. So they would last you a while.
Thank you for the reply. I’ll go with copper plugs for this case then, NGK has two Coppers, one is labeled V-power, the other being standard, not exactly sure if there’s a big difference so i’ll go with V-power (im a sucker for marketing). Also forgot to mention that i’m adding in the spark plug seals, i assume its like a gasket, change it with the plug. Also have decided on NGK plugs to keep things simple. I am worried that i may need to change the coil pack as well since i read that failing or damaged spark plugs or wires can damage other parts of the ignition system like the coil pack, and aside from the audible tick in the engine bay i think i do feel a very slight jerking of the car when im stationary or idling, its not a frequent thing but noticeable a couple times a minute, nothing to note when driving. I understand keeping things original and OEM is important so i don’t mind shelling out for the Mopar coil pack if need be, given the age of the car, even if the mileage may not be so high im not sure hoe much more life the original coil pack has left in it, especially with the already mentioned problems.
You can test the coil pack with a standard multimeter. If it's in spec, I don't see a reason to replace it.
Good time to update the status of this, i ended up going for new spark plugs (NGK copper) , ignition wires (NGK as well), and a new ignition coil pack (Hitachi). I understand the recommended advice was to keep the coil pack original, and i don’t intend any disrespect to the advice of those who have much more experience wisdom and knowledge with this platform, im really glad to have had the input, in my mind i’m really more comfortable with making sure everything is replaced with new parts that may last longer, even if the original coil pack probably had another 40 to 90 thousand miles left of life in it. Maybe the new coil pack won’t last half the time that the current one has in it (although given Hitachi is an OEM manufacturer for a few Japanese automanufacturers i do put trust in their products). That will be on me if it does not last so long. Im just more comfortable with the idea of replacing it given how old it is alongside the current issue, which may or may not affect coil pack. So that is my current state of things.
Day after replacing the old parts and the car rides smooth again. No more tick and no more chassis-jerk when stationary. Spark plugs copper NGK BKR6E11, Coil Pack Hitachi IGC0147, and Plug Wires NGK 8103. I think i should edit this thread's tag to be resolved but I'm not seeing how to edit it from 420A to Resolved. Sorry if I'm blind
  • Wanted 6 bolt NT water pipe
    • chrisman287
