2G First Gear Pops Out
GIB
133
49
Jul 9, 2012
Chicago, Illinois
2g GSX Manual
6 puck clutch. Lightweight flywheel. ACT Xtreme duty pressure plate. Extended slave rod.
First gear keeps popping out when I try to take off in 1st gear. The pop outs started last week. I added fluid but, it didn't work.
I've read through several threads and can't find a reason. I had this happen years ago, but it went away randomly.
I've never replaced any bushings. I can move the gear into first very easy by hand I'm the engine bay and when the car is stopped.
What causes this?
What steps?
What can I adjust to help?
Is the transmission going out?
Pictures below show what some things look like in case someone can see the problem.
Please help.
Above is the part above the clutch pedal. Can this be adjusted?
Take the cable off and shift to first manually. If it still pops out it's likely inside the trans.
I recommend getting rid of the extended slave. If the clutch doesn't work without it you have other problems.
It's also been my experience that first or 2nd gear popouts are worn bearings on the intermediate shaft or worn shift forks. By all means rule out the cables, weight hitting something etc. Cables are not adjustable on 2g if I recall correctly. If there are adjustments they would be at the shifter in the car.
Thanks. I read the write-up above.
Will shifting manually without the cable and no pop outs rule out worn bearings?
I will update tomorrow with your suggestion.
I had this same issue with a trans I picked up from the junkyard although I’m fwd. 98% of the time it would pop out. Sometimes if I really slowly slipped out of 1st by riding the clutch more it wouldn’t and sometimes if I held the shifter it wouldn’t but ultimately I ended up getting another trans and that solved my issue. I put solid bushings at the trans side of the cables hoping it would help but it didn’t.
Definitely get rid of the extended rod you’re causing more harm than good in the long run.
Agree with post 3. May end up having to replace tranny bearings, forks, and adjust bearing preloads all inside the tranny. But check all other possibilities before pulling tranny, including making sure shift cable casings are being held in place properly near the tranny (sometimes they break free or move around in the hold down brackets causing shift problems). Also undo any "skateboard bearing mod" which wears shift forks down, personal experience (read here: https://www.dsmtuners.com/threads/youre-not-a-true-dsmer-unless.528362/page-2#post-153760144). BTW shift cables are not adjustable on 2g. And if the internal 36mm shaft nuts get loose that can cause popouts/fork wear since it allows the shaft to move longitudinally.
I concur. I do not and have never used the skateboard bearings.
If the end nuts come loose that should only affect 5th. Shafts cant move, they're held down by the bearing plate
*UPDATE* I just unhooked the shift cable and put it into gear manually. It did not pop out of gear when trying to move it. I tried it 15-20 times and it never popped out. I connected the cable back up and it popped out a couple of times.
You all think it is the cables?
Seems pretty definitive. Look where cables attach to trans for issues.
Could be your bushings if cables are fine
If cables are shot AND you don’t want to pay for used cables you could use the K series cables.
Nice! I will get those and try it.
I saw that the bushings here were shot. That bracket holding the clips on in the picture moves like crazy when I shift.
Does anyone know what these bushings are called exactly?
(I'm still searching)
Yes I checked the bolts and they are not loose. I went through all of the rubber pieces, and the cables from the engine through the center console and checked their movement.
  • Wanted Looking for T25 replacement
    2G, preferably a t28 or t25
    • Mando Vee
  • For sale 2g 2G Manual Shifter Cables
    2G Manual Shifter Cables $85 + shipping and paypal feesYou must be registered to see element.
  • Wanted 2g Factory radio brackets
    Looking for some factory radio brackets.
    • jesse12345
  • For sale 1G DSM COMPLETE A/C UNIT
    Came off a bone stock 1G, won’t be using. Good for anyone that’s looking to go back to a/c or...
    • The_Partout_Spot
  • For sale 2g 2G AWD OEM Grey Hatch Carpet
    2G AWD OEM Grey Hatch Carpet $40 + shipping and paypal fees* Great condition with backing...
