1st gear pops out
617gsx
Jan 3, 2005
Boston,
Whenever I drive in first gear and let off the throttle and the RPMs get low, the shifter pops out of gear. Anybody know what's wrong?
same thing happened in my gst. from what i understand this is a pretty common problem in 2g's. do you have any grinding problems when you shift?
yea, 1st and 2nd gear would sometimes grind when i shift into it
could be a worn shirt fork, worn 1st gear, worn 1/2 hub and slider, worn intermediate shaft end bearing, worn spring for the 1/2 rail or something blocking your shifter.
