yet another no start question???
jakedasnake
Mar 18, 2005
brandon, Florida
I've read just abot every thread on here and non relate to mine i daily drive my 99 eclipse gs-t spyder and on the way to work from school i was pulling up to a light with my music on and all the sudden everything shuts down i have no hazards no sound no nothing as if someone disconnected my battery so i push it to the side of the road embarrased and start looking for a loose connection and maybe a blown fuse or something but cant find anything but my neg battery terminal a little losse so i tighten it up thinkin that will be it i hear my door open beeping so i got to turn the car on and as soon as i turn the key to the start position every thing cuts off like i disconnected the battery again WTF!!! beatentodeath: i work on these DSM's all the time and you would figure i could figure this out i checked the battery13.8 checked starter it's good checked altinater it was good checked all my fuses and the main relay nothing was bad and no loose connections that i could find HELP ONLY MEANS OF TRANSPORTATION be4 i give up :cry:
Do you have a front strut tower bar? If so, did the positive terminal ground out on it? Did you check the the battery grounds, specifically the main ground going to the bell housing? Start by checking continuity between the battery(-) and chassis/engine. Check cable ends for breaking/fraying. Also, check the main fuse under the hood(either 80 or 100 amp, cant remember) at the fuse box.
If you were able to tighten the ground cable and get some power into the car, I would suspect dirty/poor connections.
i'll try again cause thats the only thing i can think of is the bad connections cause only sometimes when i remove the negative terminal can i get power for the accesories it takes me like 10 tries or ten minutes whichever come first i do have a strut tower bar and i'll check that too but i did check the main fuse it looked good thanks for the suggestion i'll post back after checking thanks alot
  • Wanted 6 bolt NT water pipe
    • chrisman287
