Y Fitting for Dual In Tank Walbros
tscook3
81
Dec 2, 2008
Chambersburg, Pennsylvania
Hey guys,
Was wondering if someone could direct me to a link of this fitting? It is a 3/8 x 3/8 x 3/8 in that brings together the fuel lines of the dual walbros in tank before they get out of the stock sending unit. Don't want a distribution block or anything with a/n fittings etc, just need one so I can slip on my three 3/8" hoses. I was looking at a thread a while back and saw a link to where you can get one from but I've been looking the past couple days for it again and can't find it (both on here and internet). Seems like something like this should be easy to find? Let me know if you can help.
Thanks
Thanks for the reply. Wish I would have saw this earlier. Now I have a new question. I ordered a y fitting in which the hose just slips on (as I was looking for), BUT, it was portrayed as a brass fitting and sure enough I get it and it is plastic. My question is, does anyone know if this will be ok with gasoline (in tank)? I don't see why not, it is a very sturdy plastic fitting. I wouldn't think that the gas would eat away at it. Gas jugs are made out of plastic and there are plastic pieces inside the sending unit when in tank. This should be ok right?
Let me know
plastic ones should be alright, as long as you don't clamp down to tight assuming that you are using regular hose clamps and not the high pressure fuel injection hose clamps.
Thanks guys. That is what I thought just wanted to make sure. As for the link you posted, that is nice. That is exactly what I was looking for but in 3/8". But I will just stick with this plastic since it seems it will be ok.
As for the clamp point you made, those are the ones I used. I tightened them down decently, guess I better go loosen them up before I drop the sending unit back in the car! LOL
