diambo4life
- 1,904
- 900
- Apr 18, 2002
Edmond,
Oklahoma
That's well put together.
Seriously bad move with the plastic "Y".
How so, and please explain in depth.
Sorry guys I haven't checked this for awhile.
diambo4life - Thanks bud
slowgsr - Thanks. Yeah it is a 3/8 fitting which is equivalent to a # 6. It will work great for me and definitely saved me some major money.
Freudie1 - The y fitting should be ok. Fuel rated plastic? Not sure. I've never heard of a plastic given a fuel rating. It is a very sturdy plastic, not flimsy by any means. Aren't gas jugs made out of plastic? Yes, gas is somewhat corrosive and it is a little different with the pressure of the fuel flowing through it over time but why not give it a try? Really, who wants to spend between 30- 40$ on a fitting? I don't. In the future, I might upgrade if I have to, but for now atleast it is outside of the tank where I can monitor it. As for the angle of the fitting, is it really going to make a difference on whether the y is outside the tank or inside the tank? I doubt it. If it does, it probably isn't very significant. It just brings the fuel together at a different point. I honestly think it is a little nicer set up the way it is know. About the e85 point- do a search on google- e85 is acutally not much more corrosive than regular gas, if at all. That myth has been "busted" :
E85 Ethanol Is So Corrosive. It Will Eat Your Gas Tank And Your Fuel Lines. Myth by Change2e85.com
or
E85 Conversion Kits Change2E85.com
They are obviously different in how they are made/ what they consist of, but they are actually very same in their acidity. As for the wiring- it wouldn't hurt to redo the wiring like you said but why waste your time on something that is probably not going to benefit you at all, or if it does you probably will not be able to notice. As with my setup and most others that rewire their pumps, they only retain a foot or two of stock wire. With my setup ( wires doubled up, grounded on the sending unit, power to the stock location), I believe it will be pretty efficient. The wiring on the walbro harnesses is 14 gauge, which isn't that small. To strengthen the ground point, I ran a ground from the battery in between one of the mounting studs for the sending unit and bolt. The power is already strengthened through the 40 amp relay and 10 gauge wire. That takes care of the power and now the ground is stronger. I really don't think it is worth the effort to do the extra work. If you want to- cool. Some people are anal and that's fine. I KNOW mine will work great. That's all that matters. Everyone is different and has their own opinion on the " right " way to do things - that's all.
Glad to hear its working, acually picked up some Y fittings (plastic) through work. Have had no issues, and also pulled the pumps out after 2 months, and no sign of any fatigue.
Ideally a -6 AN would be good enough. It's a 50 trim turbo which I believe only flows 55 lb/min, but I don't even think you need to go to dual fuel pumps if you're shooting for 400 hp.
I really done know if you were to use e85 but as long as you have a Walbro 255 pump you could do it on pump gas.
one Walbro will support around 450whp on E85.
Yes, you should be fine with a single 255 for now. If you ever want to upgrade in the future, I wouldn't bother with a full blown setup. They are nice and all but a waste of money in my opinion when you can do it yourself and save a lot of money (unless you like the machined sending units a lot). You should also be fine using the stock return line.
The car is doing great with this setup! It is holding up like a champ. I had the car tuned a few weeks ago and it made 471whp @ 23lbs of boost on straight pump and a stock block with a lot more to go. We could have squeezed probably around 540 or 550 on sraight pump with this setup but we were just trying to keep it conservative on the stock block! This is on a 6262 dbb .82 exhaust side with 1200cc injectors.
Nice numbers man! I made the switch to E85 and just ran a 12.015 @ 118.90. And that was on the 16G! I'm getting ready to put on the holset in the next couple weeks so I'm really thinking about going with the dual intank setup. Did you replace the entire fuel line from tank to rail? If not, what did you use to connect to the stock fuel line?
Thanks.
Wow toby awsome numbers man! What did you find out your problem was with your car not stayin running?
Hey Matt! How's it going man? Thanks, the problem was in the dsmlink. It was the deadtime setting for the injectors, I had it set way too low although I was only going by an example setting on dsmlinks wiki section which gave the value for my size injectors. It just needed uped.
You'll have to give me a text or call sometime. My phone has been down for a long time but I have been using my gfs until I feel like getting another one. 717-491-4917. Keep my old though. How's your car?
. Thats awsome you got your car figured out and glad to see you got some good numbers bro! My cars coming along pretty good. I got my issue figured out and took it around the block the other night for the first time in about a year in a half and man let me tell you it felt pretty dam good
Ive just got alot of tuning that needs to be done.^^^ Many guys (myself included) have two pumps running at all times. If each one was on it's own relay and one relay failed, it could be catastrophic in a high pressure situation. If they share a relay and the relay fails, the car shuts off.
If your one single relay is large enough, there won't be any problems. I have a Denso 280LPH and a Bosch 044 running through a 40 amp relay and I have no issues. I'll probably bump it to a 60 amp this winter just for added piece of mind, but to my surprise, the 40-amp has been doing it's job just fine.
When I posted that, I was assuming the 40-amp wasn't enough to cover my pumps. But as it turns out, my Bosch drew about 15 amps and my Denso about 20 amps, so I stuck with the 40-amp replay and it's been just fine. Although the relay has got prety hot in the past, and I'm not sure if that's normal or not.Ok I know this is SUUUUUUUPER old, but I was doing some digging to ensure I had a reliable eletrical system for my dual wally fuel pump system and came upon this thread.
Paul, why would you go more than a 40 amp realy? I found that the Walbro 255 pulls 11.5 amps max at 14 volts. So this would be 23 amps total. Even a 30 amp fuse should be able to handle this (though I went with a 40 amp). What was your thinking for going with a 60 amp fuse?
