gst set up let me know what you think.....
nikkeebabee
253
Jul 21, 2004
Rochester, New York
well im new with 4g63s and i fell into a hell of a deal on a gst
heres my set up im planning on running well its what i will be running becuase i spent the money on all of it well here it is:
Slowboy Racing 20g turbo
apex'i 3" downpipe
apex'i 3" exhuast
dejon tool intake
slowboy racing 650 ball and disc injectors
greddy 24r front mount with pipes
greddy type s bov
1g throttle body
1g manuel cams
apex'i s-afc version 1
act 2100 clutch
im planning to set the boost controller to 20 psi to start... anything you would recommend doing or not doing with this setup what tires should i run i would eventually like to get the hks cams but till then i'll be running the 1g manuel ones
all comments welcome the car will be spending some time of the dyno as soon as its running i just tring to get a feel for what power i will trying to put down
thanks in advance
I think thats a killer setup, What fuel pump? 255hp or 190? Air fuel pressure regualtor? How about getting the car tuned, will you be purchasing an wideband tuning system? Like innovative o2 wideband? If you happen to haave the $ to fork over for that kind of setup, Maybe purchase an quife lsd so both your tires spin at the same rate itstead of having most of your power at the passengers side tire? Plus consider how many miels is on the car, maybe you like to get your tranmsission rebuilt? By shepherd? costs around 900$, jsut a suggestion? :thumb:
congrats on the GST. Your setup looks good. one thing you must work on, and i own a 98 GST so beleive me when i say the key to your performance is in the suspension! Make sure you get yourself a good set of springs/shocks or coilover setup. either way you have to get something with adjustable shocks/damper. aside from that best of luck to you.
well i missed a few things the car is actually a shell came with no motor but has a tranny that was rebuilt the suspension is eibach pro kit with tokico 5 way adjustables i know i will have a tough tim ewith power to the ground im looking into getting an lsd
what tires would be recommended i know slicks would be best but slicks arent exactly best when driving the car around on the street thanks for all the comments guys keep em comin :thumb:
