XTUNE GST N 3" cat back !!!
I don't have a attitude I'm sorry if it comes across that way but not my intension. I simply posted about the exhaust and to show how it looks and how it sounds and so far how it performs. The points you guys are trying to make are understood but I just don't agree sorry. I understand that your trying to educate me but I have modded a FEW cars and understand the diffrence between therory and real life especialy with dsm's. My 2gnt is my first non boosted car in about 2 and a half years(87 toyota supra x2, 90 talon tsi awd) so I have seen atleast 3 exhaust systems and the effect they have on performance. That article as informative as it is is just theory. saying 300hp is pusing it for a 3" exhaust is rediculous. There is a 11.09 sec gs-t runnig on a 3" exhaust with a custom 2.5" dp makin 443whp. Trust me I understand the theory but it's just that theory. I understand you two like to be safe rather than sorry that's why one of you is running a built motor on a 14b setup and the other is aiming the same path except a 16g but i'm not that how I mod. Thanks for the imput though :thumb:
Perhaps I can give some of my "real life" to back up the theory that 300 hp is pushing it for 3-inch exhaust. Running my small 16gG, I have verified via logging that going from 3 inch to no exhaust does help. And significantly! Look at the lbs/min logged. This is in the 19-22 lb/min range. Nowhere near the 300 hp mark. Yet dropping the 3-inch exhaust made a notable difference. Both logs were done in the same hour on the same day at the same elevation.
This 3-inch exhaust consisted of NO cat and a little nothing of a resonator (glass pack) for a muffler and a resonator tip. 2.5 inch at the o2 housing transitioning before the turn in the downpipe to 3 inch via a smooth cone seen here. All mandrel bent. Great for laminar flow. But, running no exhaust was significantly better.
Here's the spreadsheet compiling the two logs.
On the matter of diameters and volume. Diameter is the usual determinant of volume of an exhaust system. Considering that most will not alter the exit point on the car or even alter the path the pipe takes to the exit. Thus, when one refers to diameter it can be almost directly proportional to volume in a mandrel bent pipe.
HOWEVER! For the sake of n/a applications AND turbo applications any sudden change causes a negative affect that adds up as more flow (turbo) or more pulses (n/a) are exhibited.
Turbo and exhaust neck downs:
Where you have a neck down you increase velocity in a consistent flow system. A simple look at Poiseuille's Law will give a better understanding. Note the much more drastic affect that radius (diameter) has on the flow versus length. To the power of 4! Thus those small lengths of 2.75 inch piping in your 3-inch exhaust will definitely have an appreciable affect on flow. This is not theory. This has been proven law.
Poiseuille's Law was originally formulated for incompressible fluids. But where a fluid can compress, it will where there are bends and transitions. Since exhaust gases are not "Newtonian fluids", then the small length of diameter has a significant effect AND the act of transitioning has an effect. Using this formula affords the easiest "math" to explain what has been verified by experiment.
But delving deeper into non-Newtonian fluids, we see that we would need to measure the individual momentum vector of each exhaust gas particle as the medium meets a transition or bend or "Y" or end. Where there is reduction, simply the gas has a momentum vector to strike the wall of the reducer pipe. The sharper the transition, the larger the right angle component of the momentum vector is that hits the wall of the transition. This "reflected momentum" causes the gas particle to slow or even travel backwards into the pipe. This "adds up" as the flow increases. So what would minimally affect a 14b powered car, will drastically affect an evo3 16g powered car at their respective flow potentials. The more the flow, the more particles you have doing negative work on the exiting gases. Again, considering that my 3-inch mandrel bent exhaust has bends, there was a significant increase in flow removing the exhaust system all together.
N/A and exhaust neck downs:
N/A exhaust flows in pulses. Where ever there is a transition, "Y", or end some of the pulse is reflected. This causes a rise in pressure. This was noted and postulated by Helmholtz. And all good headers and intake manifolds follow this theory and thus have proven the Helmholtz resonator in the "field". Where you can tune the diameter and length of a pipe for a pulse frequency then you can use that pressure rise and pressure drop to scavenge, or suck, the gases along the pipe. ANY transition or Y will alter that pulse tune length to that point of change. Is the exhaust tuned for your ideal rpm range? Not likely. But, having transitions at random lengths, will cause the reflected pulses to work against each other. NOT GOOD!
Again, turbulence has an affect on pulsed gases in identical fashion as constant flow. This is what creates the Helmholtz effect. One good thing about the Helmholtz principles is that you can tune to harmonics. Thus you can have a consistent diameter tube that can resonate at two or three rpm points. A very long, consistent tube will not have any reflected pulses conflicting w/ each other and will still exhibit good scavenging properties. If you have points of turbulence, you have to be very careful about placement. You have lots of math ahead of you and lots of testing.
Either way, avoiding transitions is ideal. It has been suggested to take out the transitions. If you can modify the exhaust simply, why not? There's no reason to have "big boy" exhaust and not have the potential to get all the flow out of it that 3" diameter would suggest.
Leave it to monster to start off with simple real life stuff then make it a science class ROFL
I agree with everything that you said man mainly because my head hurts to bad to come up with anything sceintific to show you my POV on the issue. But in as simple as I can put it you were running a 16g. A 16g will create more backpressure than a larger turbo which is why it's not as effecient as the over abundance of backpressure the little 16g creates makes for hotter temps and so on. In a nut shell it takes a 16g a lot more effor t to push 300hp then a 60-1 or 50 trim. Just like that first article said you alow the turbine to work more effeciently with less back pressure, but a turbo that doesn't need to work as hard doesn't need as much backpressure eliviated to produce the same numbers.
Now I'm no master mind or anything liek that but even if all the science doesn't add up to prove my point the dyno doesn't lie. The dyno and the tree are the only thing that matter. I know people with full free flowing(3" high flow cat and 3" o2 housing) that push over 400whp. Matter of fact the largest I have seen on anyone around here is 3.5 and that was only the cat back section and that guy was makin 500whp.
vassil : 2.5 o2 > 3" test pipe > 3" thermal cat back 10.9
Tort9320g: BR 3" full exhaust 11.031
r10performance : BR 3" turbo back 11.08
awddynamite: 2.5dp > 3" cactback 11.09
johnnytsi : 3" tubro back 11.11
I could continue but I think everyone gets the point. So if 3" full exhaust takes you deep into the 11's even high 10's I think even at worse case a 2.75" exhaust will be ok on my max like 250whp 420a
Who is trying to interchange either variable. We are merely explaining how each variable is effected by the other. Not that one is replacing the other.
btw: Paul, read your pm =)
In that case why even bring up velocity then cause all teh velocity in the world isn't gonna mean jack if it's not flowing. I can have a .5" pipe and the velocity will be higher then both options but I doubt it woudl flow very well.:notgood:
Lets start a new thread for this cause this has nothing to do with the XTUNE exhaust. I'm done debating exhaust flow in here. The kit is nice sounds great and is 3" but has 2.75" necks as shown in the pic. For 171 shipped it's well worth it even if you decided to have the ends made to true 3" ends. The muffler is gigantic without being tacky and has a great sound as I showed in the video(this all with stock front piping). That's all from me.
Looks like this has been beaten to death enough but the origional example of smaller turbine housing creating quicker spool & applying this theory to back pressure in the exhaust to create quicker spool is incorrect (but we don't need to go though that here)
dsm-onster: Just to verify as I didn't happen to see it in your post of 3" vs no exhaust but for both of these tests was boost monitored & was equal? Most of the time reducing exhaust restrictions will increase boost pressure, so if this is the case, the data would no longer be useful comparable data.
As for what this post is about, looks like Chine (or where ever it was made) did a pretty good job of knocking off Apexi's R&D. For the price seems like a pretty good deal, I too would want to take those bottle necks out & weld in some new flanges for a continous diameter throughout the system. Velocity & flow defently aren't the same thing, these restrictions will increase velocity at the point of restriction but flow in general will be reduced.
I'm pretty sure everyone here already knows the difference between flow and velocity, but for some odd-random reason you want to keep bringing it up as a rebuttal to who knows what?
Final conclusion: You now own a bottle-necked Apexi' knock off exhaust that you only paid $170 shipped for. You have the option to cut off the very small tapers and reweld new flanges to make it a true 3" exhaust for minimal cost or simply keep like it is and still have a better "flowing" exhaust than the 2.25" exhaust from the factory. Either way for $170 bucks thats not bad at all my friend. The information I gave you was to be informative not argumentive I'm sorry you don't understand it or find it to be useful in any form. Goodluck with your new exhaust.
Noted and thanks
I saw no change in boost. Based on my Phantom 30 psi boost gauge. . . 11 psi.
Slippi, that exhaust does look good. If it sounds great, what more do you want for an n/a 4 cylinder street machine:thumb: ?
N/A or not I'm still a DSM guy and performance is important. This is my dd and i'm looking to upgrade the tb ROFL :dsm: :laser: :talon: :rocks:
I'm still trying to figure this crap out...
4UH8ERS, are you saying that the velocity changes of the 2.75" Bottlenecks in that 3" Exhaust, is actually good... or no? LOL... I like stupid people terms!
WTF
No, I'm saying that a 2.75" all the way through exhaust would actually outflow a 3" exhaust with 2.75" bottlenecks. For the reasons stated above.
Well enough science class in a nut shell the car lost a little low end power and def pulled longer and harder up top(butt dyno but enough where you don't need a real dyno to call thsi one). Great NA or nitrous exhaust not so good for turbo and because of the necks and besides for about the same money I picked up this new exhaust and just sold the other.
you can see no necks in this bad boy
except there :mad: but that's ok I will get that cut off and a 3" flange welded on
Still has jdm angle too:thumb:
i am now the new owner of this exhasut and i love it, lost a lil bit of gas milage and low-end for now since im still N/A runnin 3" exhaust, but like Slippi said this exhasut is awsome ,looks sick and is deff light weight, i had to put in on my car on jack-stands while lying under the car haha so good thing it was light weight, n may i add it sounds nice too:thumb:, cant wait to go turbo now!!!
(not the one right above, the one at the beginning of the post)
Always glad to hook another dsmtuner up with a good deal:thumb:.
