Cat back question....
l6u9k6e9
148
3
Jan 9, 2003
Dover AFB, Delaware
If i buy the Tsudo N1 catback how will i connect the 2.5 in pipe to the stock cat ? does it just taper down and match up or will i have to get the down pipe and headers also ?
The exhaust will bolt right up to the back side of the cat. Headers and downpipe would connect to the front of the cat if bought, but are not necessary.
btw, good choice with the tsudo :rocks:
Is this the first car that you mod? Use jackstands if you are going to do the install yourself.....
Shouldn't take you too long to do .... pretty simple install.
ya this is the first car im doing "real" mods 2. Thanks for explaining... cuz i was thinking that the exhaust is 2.5 in and there is no way that the stock exhaust was 2.5 in also so just wanted to make sure that i did not have to buy a 2.5in to w/e the stock size is pipe to get them to fit. but w/e THanks for the info.
no problem man, good luck :thumb:
