Would like your input thanks
lowdime23
Mar 25, 2010
Russell, Kentucky
I have a 95 tsi has a 6 bolt with krofrozen 1 g rods and 2 g pistons i have 1000cc injectors,wally 255,FP fat intake 3 inch back exhaust ,50 trim turbo,greddy bov,dsm link,hks auper flow filter, hks wastegate,ngk wide band,stainless steel valves,lsd,ky coil overs,bqalance shaft removed,koyo radiator,upgraded oil cooler ,act clutch,aeromotive fpr
just really wanna know from what i have listed what else i would need to add to runn some good boost ?im runnin 10 psi right now and feels great but i know i have more potential in the car maybe a meth injection?? what ould be the most boost you would set in this car the way it is if it was yours sorry just really new to the dsm game thanks for all your advice
Do a boost leak test, tune your fueltrims correctly for the 1000cc injectors. Turn the boost to 21-23psi and go get it tuned! 10psi on a 50trim is usless. 20+psi is when a 50trim turbo will come alive. Meth injection really isn't absolutly neccessary on your setup unless your running 26+psi on pump gas. It does help though if your in an area with low octane fuel
defintely. crank it and tune it and let us know how much fun you're having after that :thumb:
