Wont Start
Danks
81
Dec 23, 2003
The Beach, New Jersey
i swapped my trany last night and went to start my car and it wont start .... what could possibly be cuasing this??? it turns over just fine
Did you make sure the MAS is plugged (shouldnt effect starting but its worth a try), did you unplug the harness that connects under the fuse box, did you unplug anything on the engine what so ever?
Check for spark and fuel... Make sure the MPI fuse is not blown and in the "box" on the battery.
I'm going by your car in your profile that you have a 93 correct?
There should be a box on the battery that has 2-3 fuses in it. Make sure they are all good.
i think i know the problem... some wires broke that goto the bottom of the coolant fill and i think one of them is a ground??? thats really all i can think of..... i have to fix this today im already missing work .... im goin to sleep now ( i just finished putting in the trans an hour ago) so please everyone put in there 2 cents while im away so i can hopefully fix this
