wont start
95twinturboawd
240
Feb 26, 2009
jackson, Michigan
just installed a jdm and it wont start. now i sure i did some thing wrong. im getting fuel, when i turn the key i can hear the start make noice. but when i looked at the crank its not turning over all. can i install the starter wrong?
thanks for the info/help
I'm sorry, but you just walked right into that one.
Did you install the torque converter bolts? Maybe the starter is only turning the converter. I'm sure you COULD install the starter wrong, but it's not like it could go in backwards or anything.
And seriously, sorry for the ribbing, it's all in good fun.
EDIT: I saw the clutch in your mod list, so nevermind the torque converter idea.
Does this guy not respond?
I'm guessing you installed a new JDM motor. Please be a little more specific with details too. Make sure you timed the motor correctly!
the engine and trans came installed. and i did chack the timeing on the belt looks good and i redid the cas. but why would it not turn the engine over? what else should i look for?
its a 5speed
this is on my 92 gsx
