Wonder From Mods ?
Status
Not open for further replies.
Eclipse223
88
Jan 17, 2003
Lovington, Illinois
Ok guys have not been on in awhile so whats up everyone got a few things new to the GSX this is an AUTO!!!! 97 GSX . Mods are as listed INTAKE, 3'n down Pipe, Intercooler piping upper and lower full with bov, new manafold new timing belt like 1000 miles ago. Ported BIG T28 running 18 to 19LBS of boost lauches at 3600 with full boost spins tires for a sec. or so "all 4 tires". What type of times should i run also i hit fuel cut around 21 lbs of boost shouldn't it be like around 17 or 16 lbs of boost. Thanks Guys oh and car is running GREAT. other then it runs so freaken rich people behind me complain what do i do about that???? AND its only get like 200 or less miles to the tank not driving hard on highway OUCH....
Thanks Alot Guys.
Brien
It could have an upgraded pump, injectors or both. Try to determine what it has and get an AFPR to control the fuel. Mark
Eclipse223 said:
"all 4 tires"
Actually, only two tires are spinning. If you had the 4 bolt rear, then you would get "all 4 tires" spinning. But being that you have a 2g, only two.
You will need to get some type of engine/fuel management system such as a DSM Link or a stand alone system.
P.S. Yes, it does sound like bench racing, which as far as I know, is not allowed.
Status
