2G Wiseco evo pistons turbo tuff rods
GSXvsTSI
147
14
Aug 11, 2015
Pleasant Grove, Utah
I'm building my engine and bought some Manley turbo tuff long rods with 22mm wrist pins.
These will work perfectly with evo pistons but i'm trying to figure out compression ratios(because evo pistons aren't as tall as 2g pistons if im correct).
The pistons are going to be wiseco and here are my options.
-1400HD .020" 9:1 150mm rod
-1400HD .020" 8:1 156mm long rod
-1400HD .020" 8.8:1 153mm stroker piston
-1400HD .020" 9:1 150mm stroker piston
I want the compression ratio to be between 9.5:1 and 10.5:1
If none of these will work i can just get wiseco's normal 2g .020" 156mm 9.5:1 pistons
