Wiring Up A Shift Box
Simon Tibbett
Jan 8, 2008
Athens, Georgia
I am wiring in a toggle switch to change gears as I search for a TCU, does it go like this:
Connector B-24
Pin 1 Blue wire Pressure Control solenoid unswitched; leave connected
Pin 2 Red wire Lock-up solenoid toggle; 12v switched on for lock-up
Pin 3 Orange wire Shift solenoid "A" toggle; 12v switched on for 1st & 4th - off for 2nd & 3rd
Pin 4 Yellow wire Shift solenoid "B" toggle; 12v switched on for 1st & 2nd - off for 3rd & 4th
This is on a 1992 Plymouth Laser turbo FWD A/T.
Shift sequence:
These pins are on the TCU harness correct?
PLEASE some input on this so I can drive this car. This would prevent limp mode right? As I would be manually shifting.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
