fuse box and wiring
wolfdawg
Aug 15, 2008
conestoga, Pennsylvania
I dont know if this question was answered but maybe somebody can tell me. 95-96 vs 97-99 is there a difference between the fuse box in the engine bay to the plugs underneath the dash are they the same? Example- can I use a 95 wiring harness in a 98? This is for the turbo model. I know there is a diff in the evap and having a sensor and what not but im not really worried about that. I just wanted to know for the light wiring and the horn.
No not the wiring out of the fire wall to the motor. The wire from the fuse box in the bay to all the lights,fan horn that run under the rad to the drivers side door to the plugs under the dash. Can i take that right out of an 95 and put in a 98 or did they change up some the wiring on the plugs or willl work just fine??
not to sure.
-best bet would be to take pics and maby someone on here can compare to theirs.
The 97-99 has some differences in how the harness connects in the vicinity of the junction box (inside fuse box) but over all they are very similar. You can probably adapt the box to work with your car with minimal work.
Did you damage your fuse box or something?
Well i doing a wire tuck i know alot about the cars just i never got into all the wiring. Ill just have to pick one up and see for my self.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
