Spyder Fuse box Wiring
Ceezdsm99
108
17
Mar 11, 2022
California
I recently picked up a gst spyder , it used to have a relocated battery in the trunk but the previous owner “re wired “ it back to the front . I start having starting issues and it turns out all the wiring was done very shitty and ghuetto , the 4 white wires from the fuse box were crimped together on an extension bolt thing - straight to the battery and that’s where it came loose .So I ran to the store and got terminals and wire , the starter Power wire is directly on the terminal to the battery and the fuse box wires i crimped them as good as I could , with electrical tape/heat shrink and a plastic cover Just want to know Is there any specific way those fuse box wires have to go ? Or aslong as they’re connected properly to the battery
Two of the white wires go to one terminal on the fusebox and the other two go to a different terminal. They supply power to fuses on different circuits. See link below. Also solder those ring terminals on each pair or you will have problems down the road.
