Wiring gremlins
rocketrapson
145
May 21, 2012
Cumberland, Maryland
I've got some serious gremlins in my interior wiring system and would like to fix myself if possible, here are my issues.
1. Obd2 port stopped working - put a test light to it and no power, all fuses are good
2. Cig lighter went out - no power with test light, fuses good.
3. Dimmer switch will dim interior lights but will not turn on lights - have not had any testing on this, fuses all good.
4. Power doors will not lock with remote or switch - not test light testing, fuses are good, when I pressed in on the fuse the locks worked with the switch but not the remote.
I really hope I can solve this myself, I don't want to put my car in the shop.
Car is running perfect, a while back I had a cel, swapped out my spark plugs and it cleared out. No performance issues since. It is massive pain having these wiring problems because once I make my move back to md on the 15th im going to be starting my actual build. I plan to purchase and run dsmlink v3 shortly after the move and this is a big roadblock.
On the fuse box theres a screw that holds on of the fuses in. I think its the alternator fuse. But check and see if that screw is tight. It has positive or ground wire in there. When my obd2 port wasnt working that was the problem.
