Wire tuck, alternator wires
tylercuevas93
Oct 19, 2012
Valparaiso, Indiana
Coming off the alternator are two wires, white, and white/black. They have "plugs where they connect to other wires of the same, and I am having problem because I didn't label the white/black wire on locating the plug. It's literally my last plug to locate before being finished with the tuck! Please any help would be much appreciated, I've looked over google and on the forums for hours and even through my manual and I can't seem to find it!
I have pictures of the wire/ female plug, and can send to an email if need be. I just need the help locating the male plug. The white wire female is plugged in by the hole for wiring by the drivers side fender.
There are only 2 white heavy gauge wires coming off the alternator, these are the charge wires that go to the fuse box.
The other wires are in the alternator connector (grey, 4 pin): http://www.dsmtuners.com/forums/151542316-post47.html
The white/black wire you are describing sound like the ignition switch wire that comes from the engine bay fuse box and plugs into the interior fuse box. I believe the other white wire also plugs into the interior fuse box if my memory serves me right.
Post up some pictures.
Looking over my wiring I was just about to come in and correct myself. You were 100% right! Plugged into the back of the interior fuse box, thank you so much for the guidance! Don't know what I'd do without this forum! Thank you so much for the help, that last plug was driving me insane!:thumb:
