wilwood brake setup
bonusboy
60
Aug 20, 2011
Calgary, AB, Canada
I have an old set of Wilwood with the .80 thick rotors that don't last very long. i picked these up a while ago and they need new rotors.
The old rotors measure 13" and are a two piece design. However Wilwoods website and catalog don't have any info on these and are discontinued.
Does anyone know if 13" cobra rotors will work or any others?
the hats and rotors have no part numbers but the callipers are KU-120-8464L/R
i would like to install 13x1.25 rotors solid or 2 piece doesn't matter to me.
not ideal but
13" = 330mm
12.8" = 325mm
If the calipers are radial mounted, you could just use their 12.8" rotors and have the brackets milled down 2.5mm?
You will probably have to change calipers and possibly brackets to fit a thicker rotor
not ideal but
13" = 330mm
12.8" = 325mm
these are the old style conventional mounted callipers!
thanks ya i took a look at his site and thats exactly what i need
OUCH rotors $160 each!
