twicks69
Supporting Vendor
- 4,313
- 2,034
- Mar 12, 2004
Milwaukee,
Wisconsin
I am in the process of parting together a better rear brake system for my 1999 GSX.
My current setup is Wilwood 12.2" x 0.81" scalloped front rotors on Wilwood cast aluminum hats with Wilwood Forged Billet Superlite 4-piston calipers on TCE Performance brackets with Wilwood D-pads, and stainless lines. Ther rears consist of stainless lines and EBC Green pads on stock calipers/rotors/e-brake assembly.
I am looking to remove the stock E-brake, and replace it with a hydraulic hand brake (preferably one that can lock so I can utilize it as a parking brake).
The brake setup I am going to be running will revolve around Wilwood scalloped 11.75" x 0.81" rotors, Wilwood Dynalite calipers and Wilwood BP-10 pads with stainless lines.
The two things I will need to still do will be caliper bracketry, and rotor hat sizing to fit the application.
Now....those are my two major questions.... Has anyone ever used 11.75" rotors with a Dynalite caliper, and what did you do for your caliper bracket? As well, what size rotor hat did you use to offset the brake rotor?
Finally, I will need to purchase and install the hydraulic hand brake. Could you give me some information on who has the best hydraulic hand brake for our application? As well, I would like to have it capable of locking for parking-brake usage. How should I do the brake plumbing to install the hand brake?
This application will be used primarily for drag racing, and I will be using the hand brake for launching. I will have my parachute also. This setup is just going together to reduce unsprung mass and provide a better hand brake for launching at track.
FYI, each 12.2" scalloped rotor weighs around 4.8 pounds, and the 11.75" rotor weighs 4.4 pounds!
I appreciate any help that I may get!
Thanks,
Thanks,
