2G Custom Brake Line Help
Blurred Talon
2,307
44
Jan 2, 2004
Paradise, NL, Canada
Working on making new custom lines for my car from Nickle Copper tubing.
I'm running an Lancer booster which is all double flared M10x1.0 fittings.
Are the 2G DSM brake lines the same fitting where the flex lines connect in the wheel wells?
Also where can I get stainless brake fittings?
All the evo lines are different flares, they wont match up, its been discussed here a few times before. You have to get pre made lines or lines for a DSM, the booster from an evo (im assuming you mean evo) by saying lancer? Correct me if im wrong, the MC is a different flare inside that aswell, so using hardlines from the oem system is not going to work, if your using new lines that your making up just flare them correctly with the right nut and thats all good,
Have your changed the MC aswell or just the booster?
I mean Lancer, I'm using a 7/8 MC from a Lancer (non Evo) - I have no booster as it's been deleted.
I've got the fittings for the MC but where my hard lines go to the flex lines in the wheel wells - I need to know the size. I'm still running stock 2G AWD brakes.
