will this interccoler piping work? its ebay
IT will work fine. You are going to have to cut and modify the piped to get it to fit your application. I would go with 2.5 inch.
It look like it should be a good universal kit. I myself would go with a 2.5 in piping kit. but thats just my opinion. Either way you go good luck to you sir.
Yes, I would trust almost anything from ebay that isnt a moving part. As another member alluded to, you will need to cut it to fit.
True piping is piping. I used exhaust tubing from my local muffler shop when i first started out and didnt have enough money to buy a nIce kit. I think 2.5 will do just fine.
What are the inlet and outlet if the IC you will use?
If the IC has 2.5 inlet/outlet then use the 2.5 pipe.
If the IC has 3 inlet/outlet then use the 3 pipe.
The clamps are garbage. While the band on them is stainless, the bolt isn't.
The piping is piping.
The couplers are alright.
If you haven't bought a FMIC yet, I'd look into buying a kit made for our cars. When I used a universal kit like that, I ended up with 9 pipes, 9 couplers, and all those clamps. Boost leak testing was a bit of a pain, and I was getting part throttle compressor surge. I just put a 2g VRSF FMIC kit on, and the surge has gone away.
